I'm just going to have to do something my way, and then show it. I like subtle, and upgrades.I thought I was bad with the look stock lol
As I tell my son all the timeI'm just going to have to do something my way, and then show it. I like subtle, and upgrades.
It don't function as a true gauge it just shows that you have pressureSorry for my ignorance, but what’s the problem with the stock oil gauge??
I've seen the one that goes in the vent on eBay but decided against it as it doesn't fit my "from the factory look" requirement. The column mount is one option I am considering as I can see that Ford "possibly" might have considered such a thing but think they would have most likely defaulted to doing the same thing they did in the early 2000's lighting. I'm also not a big fan of the a-pillar pod look for the same reason.member Dono had a single pod that was mounted above the radio in the vent. it did block off one vent however. he also had a column mount pod as well. i will try digging threw his old threads and see if he put pictures in.
i however have a a-pillar pod and like it. it is easy to see, the draw back is it blocks the defrost vent in the dash, and i have to fold my visor before i swing it down (made a triple pod)
Yeah, sound like a cool idea. Like to find one that has the matching green lighting of the rest of the truck.This might fit below the temp/oil gauges under the trim panel.
I am too lazy to pull mine look...
Odyssey Series I, Vacuum/ Boost
Dakota Digital manufactures digital instrumentation and accessories for the automotive, motorcycle and car audio enthusiast.www.dakotadigital.com
I thought about that - but it would really hard to fit something there.I like it, but the spot I wondered about has the left turn signal arrow in it, to the left of the shift indicator. Where you have it would be great for a couple of data items.
