bigger tires
caveman215
Green Bay, WI
1996 XL
can i put 32" tires on a stock 96 explorer or do i need to get a lift
Glen4X4
Lewistown, Pa
2000 XLS
You can but you're going to need to break out the sawzall....I'd do a tt and shackle to provide a little more room but your still won't have much flex room.
Justawajz
Annapolis, Md
02 Mountaineer
fo real bro! theres a ton a threads about this on here.. search alittle!
trj360
1999 XLT SOHC
hey man do you have any updated pictures of your truck? last i saw you on here, you were preparing for the coilover swap.
Justawajz
Annapolis, Md
02 Mountaineer
I think I have some, I'll have to dig... The coilovers are on and it drives great.. while I was doing the swap I regeared the axles with 4.56's and did a 4406 swap with a front locker as well. It did great in the snow!
wantedexplorer
Jay, Maine
96 Eddie Bauer V8
I had 32x10.5's on my explorer stock. Youll have to trim the bumper maybe a 1/5 inch and if you have plastic tupperware across the bottom youll want to remove the piece that connects to the fender. After that I was good to go and was fine.
After a 2.5"tt , AAL and war153s I have more then enough room for flex turning ect. I could do 33's with out a problem now.
Put them on only way to tell .
Glen4X4
Lewistown, Pa
2000 XLS
You could probably stick a couple washers on to push the bumper out instead of having to trim the bumper.
1 So what to do with the brakes, with a slight lift, and bigger tires? Modified 1995-2001 Explorers 15
W Stock 2000 Eddie Bauer Explorer Bigger tires Modified 1995-2001 Explorers 0
T Bigger Tires Modified 1995-2001 Explorers 2
Z bigger tires Modified 1995-2001 Explorers 4
Sbyrne97 Bigger tires...computer tune? Modified 1995-2001 Explorers 1
M Suggestion For Small Life and Bigger Tires Modified 1995-2001 Explorers 10
G 2 inch lift and bigger tires Modified 1995-2001 Explorers 4
M Need a bigger MAF Modified 1995-2001 Explorers 14
M 5.0 bigger cam, no tune? Modified 1995-2001 Explorers 28
F bigger engine or turbo Modified 1995-2001 Explorers 42
A Bigger Shocks = Lift???? Modified 1995-2001 Explorers 11
H Bigger Side Mirrors Modified 1995-2001 Explorers 4
badge49 Bigger Front Disks In Rear? Modified 1995-2001 Explorers 2
K Bigger MAF Modified 1995-2001 Explorers 4
S Going bigger Modified 1995-2001 Explorers 4
A Bigger T/ bar Bolts Fitted and more lift all-round Modified 1995-2001 Explorers 0
S the xploder got bigger! Modified 1995-2001 Explorers 12
A Well I decided to go bigger Modified 1995-2001 Explorers 6
S bigger exhaust or not Modified 1995-2001 Explorers 6
G Bigger Springs? Modified 1995-2001 Explorers 4
C How much lift to mount 32 x 10.5 x 15 Super Swamper tires? Modified 1995-2001 Explorers 19
B Rims & tires Modified 1995-2001 Explorers 1
J Staggered tires on 01 Sport???? Modified 1995-2001 Explorers 6
A Jeep rims and tires Modified 1995-2001 Explorers 2
1 Who has Power Stop Brakes? Thoughts on which ones to get with larger tires Modified 1995-2001 Explorers 37
P 32" tires with EB fender flares Modified 1995-2001 Explorers 4
G New tires Modified 1995-2001 Explorers 10
C 4.56 gears with 30" tires Modified 1995-2001 Explorers 10
S 99 Sport 4x4 Wheels, Tires with 2" Shackles rear and torsion bar adjustment Modified 1995-2001 Explorers 0
E TIRES UPGRADE HELP!!!!! Modified 1995-2001 Explorers 6
J are 4.30 gears worth it with 33 inch tires? Modified 1995-2001 Explorers 13
L 31 inch tires no lift long term problems Modified 1995-2001 Explorers 12
1 Fuel mileage going from stock wheels/tires to larger tires Modified 1995-2001 Explorers 50
M Trimming to fit tires Modified 1995-2001 Explorers 4
A speedo calibration for larger tires and gear swap Modified 1995-2001 Explorers 9
E 32x11.5 tires on 01 Sport on stock 15x7 rims? Modified 1995-2001 Explorers 0
1 Which size tires to buy Modified 1995-2001 Explorers 10
9 Its amazing what a new set of tires can do.. Modified 1995-2001 Explorers 2
J wide tires Modified 1995-2001 Explorers 3
B Help with TT Shackle lift and fitting tires Modified 1995-2001 Explorers 23
4pointslow Wheels and tires Modified 1995-2001 Explorers 38
9 31" vs 32" tires Modified 1995-2001 Explorers 4
J running 2 different size mud tires on front and back? Modified 1995-2001 Explorers 6
J Found a set of mud dog tires for cheap will they fit? Modified 1995-2001 Explorers 7
1 Shopping for tires for my '96 Eddie Bauer Modified 1995-2001 Explorers 2
C Looking into New Tires Modified 1995-2001 Explorers 5
S 2000 ford explorer sport suspension and tires Modified 1995-2001 Explorers 5
S Correct gearing for chunky 31" tires Modified 1995-2001 Explorers 12
0 will these wheels/tires fit? Modified 1995-2001 Explorers 5
R Biggest tires? Modified 1995-2001 Explorers 13
Similar threads
