biggest tires i could put on a first gen 2in lift? | Ford Explorer Forums - Serious Explorations
tigercat
Perry, Fl
'92 sport
what is the biggest size tire i could put under a 1992 2wd 2inch lift explorer sport?
32s w/o regearing and losing tons of power
ok thanks what do camber shims do
Lifts and Max tires sizes sticky thread said:
91-94 explorers.
No lift- 31x10.50x15 on 15x8 inch or stock rims
1-2 inch suspension lift- 31x10.50x15 - 32x11.50x15 on 15x8 rims/ may require some extensive fender trimming
2-3 inch suspension lift- 32x11.50x15 on 15x8 rims
3-4 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rims/ may require fender trimming
4-6 inch suspension lift- 33x12.50x15 - 35x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift- 32x11.50x15 on 15x8 rims/ may require fender trimming
3 inch body lift- 33x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 2-3 inch suspension lift- 33x12.50x15 on 15x8 inch rim
2 inch body lift and 4-6 inch suspension lift – 35x12.50x15 – 36x12.50x15 on 15x 8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 2-3 inch Suspension Lift – 33x12.50x15 – 35x12.50x15 on 15x8 rim
3 inch body lift and 4-6 inch Suspension lift – 35x12.50x15 – 36x12.50x15 on 15x8 inch rim
I ran 32 x 11.50's on 15x8 rims for a long time with 2" lift. Filled the wheel wells good. I trimmed the back of the front fenders slightly. The pics are in the '92 registry link in my signature.
Camber is the angle of the wheels (usually referring to the front) to the road. For instance straight up and down wheels or wheels leaning at a angle is a difference in camber. Camber shims adjust the angle of the wheels.
how much do the shims cost
