- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
The wife had all of last week off, so the Explorer didn't get much of my time. She is working the rest of this week, which will give me time to finish up the Explorer. Spent most of this lovely hot and humid day working on the floor. I got the holes repaired, installed all the Kilmat and installed the shifters. I was going to just do the Kilmat under the front seats but ended up removing the rear seat and doing the entire floor. Its ready for me to put the carpet and interior back in, but I decided I was done for the day.
Before
Hole was for wiring to OEM transfer case
The round hole towards the dash is from the old cable shifter for the NP231, all the rest was me trying to get the cable shifter to fit.
After
It didn't have to be pretty because of the Kilmat
The Kilmat is the Federation of Russia's version of Dynamat and was available on Amazon with good reviews. Its basically some type of tar like substance bonded to very stretchable aluminum foil. There is a small learning curve, but it went down easy. It cuts easily with a POS pair of HF scissors. You can move it before you start to press it down, after that it bonds. You can just push it over the seat studs sticking out of the floor. I think it helped it was a hot day here, I imagine in the cold this stuff would suck. It came with a roller which helps it to seal. It does beat up your fingers where the roller doesn't fit, and its very time consuming. I ordered 50 square feet and ended up with about 1/4 of the box left over. I got the thinnest I could find, and ended up doubling it up across the transmission tunnel. I am very pleased with the end result. It was completely worth the effort to seal up the floor and maybe quiet down the road noise as well.
Shifters mounted
I don't think they will look this clean for very long
Neutral front and rear. It took me a few tries to get them straight and aligned with each other.
Tomorrow I should have the entire interior reinstalled. The rear drive shaft should be ready by tomorrow, and the front is scheduled to be delivered by tomorrow as well. I should have a drivable Explorer again by Friday. I am going to get it together, and drive it for a while before I modify the skid plates.
Before
After
Shifters mounted
