Valve your shocks for go fast stuff. You won't notice it at all crawling because the pistons won't be traveling fast enough. Most of the oil will be going thru your freebleed piston ports rather then thru your valving at crawling shock shaft speeds. It'll ride nice and handle nice on the street, more sports carish. If you have tons of body roll, when you have the shocks apart, close up all the freebleed ports leaving only one open on the piston. You'll gain way more in every single situation you put your exploder thru with shocks that are valved correctly then adding a set of hydrobumps will ever do for you.
(for reference, I've got 18 shocks in my driveway collection I'm responsible for tuning, maintenance, and up keep on... 6 on the race truck, 4 on my exploder, 8 on my play truck.)
BTW, I'm running 17* of caster, you should see my tires roll over when turning!
