Bkennedy's SAS and Rebuild Thread
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Looking good Brian. What did you do to prep the conduit for welding?
Ground off all the galvanized coating around the weld areas. Not much different than prepping plain tube for welding. Only problem welding is I have to move fast even with the welder in the lowest setting or I start burning holes.
The pain is prepping it for paint. I need to sand the entire rack to etch the coating, otherwise it won't stick.
Kirby N.
Colorado Springs, CO
1991 Ranger
I have been told to drink lots of milk when I am welding galvanized. I think that must be an tale though. I don't see how that would help. I just try to avoid it. Hope you are doing it in a well ventilated area.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Open three car garage with two back doors and a Snap-On fan pointed at the work area.
Finish welded the rack today. The light bar mount took too much of my time today to finish the project. The curved bar also has curved mount ends. Took me two hours trying to get fancy before I got frustrated and put a bend in some tabs I had lying around. I wanted a stronger mount due to the thin conduit. Ended up welding a small plate tying the light bar mount to the cross bars.
Nothing more until Saturday when I need to straighten it slightly so the holes line back up, smooth out my crappy welds, and paint.
Edit for some pictures
Some of the worst welding I have ever done. I normally would stop if I was doing such a poor job, but I don't have time to spare for this. That super thin metal is hard to weld nicely.
The really great parts about using EMT conduit are the cost, the pre-bent sections, it is very rigid when properly gusseted and the light weight. I estimate the entire rack, without the light bar or Hi-Lift, is about 25 pounds.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Are you bolting the through the drip channel like I did? My cage made it a real PITA to get the bolts.
The cage prevents that. Using well nuts and sealant. The rack is too long for solid mounts into sheet metal. Well nuts are flexible and allow some movement. The only thing I did not like was drilling 16 1/2" holes in the roof. If I did not have the cage, I would have found a alternate mounting solution.
I think the seam or drip channel is the strongest part of the roof. Most if what I drilled through was 1/4" sheet metal with thick sealer on top.
Maniak
Moderator-Stock 91-94
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
Any pictures of how that works? (well nuts). It looks like the shoulder on them is pretty small so it would be able to pull through.
Also, what did you do with the old holes.. I didn't see if you welded them up or ???
I need to do something with my roof rack as the front right hole is cracked.. I shoved some dynaflex 230 in there a few years ago and so far, no leaks
I need to do something to get rid of the coleman roof basket. I already made my own cross bars that use the factory rails. I either need to repair the holes or get rid of the factory rails and put a different rack.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Mark, I did not take any pictures of the well nuts. You can't see how they work with pictures anyway, as you would be looking at the top of the mount. Drilling holes exactly the size recommend by the manufacture is critical in the process. These 1/4x20 nuts called for a 1/2" hole. Whatever you are mounting to the sheet metal holds the well nut down until the threaded brass nut inside pulls up and expands the rubber part of the nut, locking the well nut in place. Sometimes you need to put a little downward pressure on the mount to get the well nuts to start the threads. Makes a tight seal. They make all types of well nuts. Some have a thicker shoulder on them. I chose a thinner shoulder due to space limitations in the seam channel.
There is a bunch here at this hardware store near my house. They stock a bunch of stuff not usually at stores. I purchased all of the hardware for the SAS there;
http://www.marshallshardware.com/products/productList.aspx?uid=2-411-203-232
All I have done with the old holes for now is seal them up with silicone sealant. It works for the RV, why not the Explorer? If that doesn't work, I will get some 3/8" automotive plugs and seal them into the holes. I am not going to weld up the holes because then I would have to repaint the roof.
I was looking over the rack and found this one un-welded spot. Break out the welder one more time....:(
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Got it all painted, despite the rain. Its just setting on the roof right now. Need to screw it down, and mount and wire the light bar. I pulled it out of the garage to wash it while the paint was drying and I almost like it better with a slick top.
Improvised paint booth
ZWilson07
Elite Cowboy
Louisville, Kentucky
2000 Ford Explorer
Looks awesomes man. Can't wait to see more pics of it on there.
Im like you, I actually tend to like it without anything on but its so useful its hard to have it on there.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Okay, now I like it again. I am pleased with how it came out. I would have liked to have made the front bars at less of an angle so they better matched the windshield slope, but then the light bar and rack would have had to be about 10" farther back, which did not look right overall. I picked an angle in between the windshield slope and the rack, which I think looks pretty good. The well nuts should work out well, its solidly mounted to the roof. Instead of drilling a new hole in the roof for the light bar wiring, I used the farthest most forward hole from the old rack rail. It would have looked cleaner with the wiring being hidden behind a rack mount, but I did not want any more holes in the roof.
Few garage pics. I will take some more out at Truckhaven in its natural environment.
The rack sits as low as possible on the roof and still be straight. The roof is at its highest point about a foot forward of the back hatch mounts, and is dome shaped. The rack is about 1/2" above the roof at that point.
sirhk100
las vegas
'91
Looks awesome!!!! You mentioned the welding and using electrical conduit? In a couple pictures it almost looks galvanized. Was it? If so that could've been what kicked your butt on the welding.
Also funny missing the one weld, it's amazing how easy that is to do. I bet the race truck still to this day has a weld that I missed and just haven't found! LOL
Wanna build another rack??? LOL
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Don't want to build anything for a while. It was galvanized, but I removed it around all the weld areas. After I cleaned it up a little and painted it, the welds didn't look so bad.
That missed weld! I turned that rack every which way to make sure and I still missed one in a obvious place. When I did the SAS, I marked the places that weren't finish welded with arrows with a thick red Sharpe.
Had to replace two of the well nuts in each side with longer ones because the sheet metal was too thick to engage the nuts. Right above the front doors.
FR-425
Used to be a road here.
Phoenix, AZ.
1994 Explorer Limited
FYI:
For welding coated and galvanized sheet steels, E71T-14 is the wire of choice. The self-shielded E71T-14 wire has core materials which explode in the arc, volatizing the steel coating, minimizing cracking and porosity. The result is higher quality welds and fast welding speeds. E71T-14 wires are widely used in the automotive industry for fabricating galvanized steels.
Quote from Lincoln Electric web site:
http://www.lincolnelectric.com/en-u...o/Pages/flux-cored-wire-selection-detail.aspx
A little late on the draw as you will probably never weld galvy again. :(
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Thanks for the info.
I am learning as I go about well nuts. Had one set on the left rear mount pull out of the sheet metal while I was tightening the others. Turns out screws 1/4" longer than the nut are not long enough. I used 1-1/4" screws and it stayed secured. I guess the shorter screws don't give it enough room to widen out behind the sheet metal.
Took this pic while I was messing around in the garage.
johnny499
brooklyn park,mn
98 Mountaineer 5.0 SAS
Callsign
W3JF
That came out really nice. I like the sloped tubes to ramp brush and such up and over the bar and rack. I contact a lot of tree branches wheeling in this area. Now i have another project for mine someday.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Finally got time to take it out for a drive today. No creaks, no squeaks, no noise from the rack. Parking lot of my favorite hardware store:
I ended up replacing most of the 1/2" well nuts with longer nuts. Most are 1" with 1-1/4" screws. More rubber under the sheet metal makes a stronger bond and a tighter seal.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Thanks. I wanted to protect the light bar. I don't know if a rack this long would work without a internal cage to keep the roof from flexing and pulling out the mount. These roofs flex a lot. Before the cage and the SAS, it used to creak, groan and complain like an old woman.
5spdman
Stryker, OH
91 Explorer XLT
Wish I had seen this before I started building my rack. Might have skipped over it but what size EMT did you use? Used 3/4" and 1/2" tubing for mine, which is still in it's build process...looks great!
S let's see your steering box on gen 2 sas Offroad Projects 4
ovrlndr Jay's '92 SAS on F150's Offroad Projects 1
KurtECV The Black Pearl SAS and build Offroad Projects 362
G 2001 ex SAS project Offroad Projects 4
C Chato's '98 V8 Mountaineer SAS build Offroad Projects 4
9 2000 5.0 sas question Offroad Projects 3
F Dana 44 purchased, SAS questions! Offroad Projects 7
L SAS on tons and 40" Offroad Projects 2
SVO42 mushy brakes after SAS Offroad Projects 6
A 2005 sport trac Dana 30 sas (Version 2.0) Offroad Projects 24
madbutcher Madbutchers shitmachine sas Offroad Projects 93
1 D30 sas/soa Offroad Projects 4
F FullBlownModz Dana 44 SAS Build Offroad Projects 18
D Project "Twisted Sister" SAS Front Dana 44, Rear Ford 9" Offroad Projects 46
A Explorer SAS or not for daily driver? Offroad Projects 1
boominXplorer Superduty D50 axle for SAS? Give me your thoughts........ Offroad Projects 7
JTX JTX's Return! 1997 Mountaineer Build Thread SAS/4wd Conversion Offroad Projects 65
CodePoet 1st Gen SAS Toyota Steering Box?? Offroad Projects 3
W Woody's SAS Build Offroad Projects 4
MidnightRebel07 2003 Sport Trac - SAS, SOA started and here's a sneek peek. Offroad Projects 118
I Getting closer to my full width 3 link sas need some help Offroad Projects 5
T Ford explorer sas project Offroad Projects 5
Stic-o 2nd gen SAS steering rubbing on exhaust manifold Offroad Projects 17
A sport track dana 30 sas project Offroad Projects 97
R 2002 Sport Trac SAS rack/pinion Offroad Projects 4
jprentice94 1st gen explorer sas Offroad Projects 20
B SAS for 2002 ford ranger Offroad Projects 0
D dersch6221992 Dana 44 SAS, with a rear SOA Offroad Projects 18
T 99 Explorer 1 ton SAS Trail Machine Build Offroad Projects 10
W 99 mounty sas thread Offroad Projects 0
K SAS to do or not to do? Offroad Projects 4
blueka Pickle 2.0 - Full Width SAS/SOA 4406 swap Offroad Projects 208
D 01 Sport Trac SAS Offroad Projects 33
C 94 explorer. Need help with SAS Offroad Projects 1
Y YoungMounty's '97 Mountaineer SAS Build Thread Offroad Projects 14
N SAS with ABS? Offroad Projects 24
X xeek's full width sas Offroad Projects 74
Stang5lgt Bronco II SAS Dana 30/8.8.... Offroad Projects 7
C Rocky Mountain Ranger '92 SAS Offroad Projects 32
Stang5lgt Project Lazyboy SAS... Offroad Projects 277
M 94 Re-SAS....leafs to links Offroad Projects 7
jjaganashi Gauging interest on SAS Offroad Projects 10
jjaganashi SAS "Betsy" 1-ton Offroad Projects 90
M mjc79's sas project Offroad Projects 7
LIFTEDXPLODER96 oh ya know just another 2nd gen sas in the works Offroad Projects 34
1 Project Green Hornet '01 Sport SAS Offroad Projects 159
turboexplorer Turboexplorer's Full Width SAS Build Thread Offroad Projects 969
D My no-budget 91 Sport SAS Offroad Projects 37
Four0Sport Jack's SAS version 3.0 Offroad Projects 270
C SAS leaf springs front Offroad Projects 2
Similar threads
