black smoke out muffler | Ford Explorer Forums - Serious Explorations
dexter2500
dansville,ny
1991 explorer
im getting alot of black soot out my muffler on my 91 explorer. when i rev it up sitting it leaves a black patch out of the muffler and im getting really really bad gas mileage ..thks if you can point me in the right direction
You need a new FPR ;)
Any check engine light? If not and it's that bad then it's not the O2 sensor.
Black smoke= high hydrocarbons
Running that rich will cause your catylitic converers lifespan to shorten. After you are driving around for awhile are your cats glowing red?
Get it fixed. Check your FPR as mentioned above.
what is the fpr and where is it located ..thks for the help
and yes tyhe check engine light comes on and off every once in a while
Get the CEL codes checked at your local autozone just to be sure.
Search for "FPR" or "Fuel Pressure Regulator" and you'll come up with tips for replacing it.
thks alec..i will head to auto zone and i found the fpr..will replace today..thks
Did you ever check to see what code was causing your cel to flash?
Was the problem the FPR?
Update requested please....:D
