Blank instrument cluster (ST digital display)
breddy
Orlando, FL
2020 Explorer ST
24hr after taking delivery of our 2020 ST we entered the vehicle to a pitch black instrument cluster. SYNC screen was fine and everything worked OK. Checked fuse 13 in the interior fuse panel - no issues. Got an appointment today with the dealer but it has now remedied itself.
Anyone seen this?
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
No one has posted about this before. You're #1.:)
breddy
Orlando, FL
2020 Explorer ST
NCcarguy
Raleigh, NC
2020 Explorer ST
My sync 3 display has gone blank before, but not the dash.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
While not specifically mentioned - wonder if this could be a remedy:
SSM 48386 - 2020 Explorer - ST And Platinum Trim Level - Various IPC Features Inoperative -Built On Or Before 01-Jul-2019
Some 2020 Explorer vehicles equipped with ST or Platinum trim levels and speedometers reading miles per hour (MPH) built on or before 01-Jul-2019 may exhibit various instrument panel cluster (IPC) features inoperative such as trip meter shows only zeros for miles/timer and dashes for MPG, fuel economy only shows dashes, eco coach shows 99 percent, unable to control dimming, and/or lighting intensity does not change with ambient light level (day/night). This may be due to thesoftware in the IPC. To correct the condition, perform the Instrument Panel Cluster (IPC) Software Update using the latest software level of the appropriate Ford diagnostic scan tool. For claiming, use causal part 10849 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
2020 CAR: TW U625N EXPLORER
breddy
Orlando, FL
2020 Explorer ST
APPLICABLE VEHICLES
Hey this is interesting but ours is a 9/19 build date. It's also now dimming and brightening from time to time. Dealer found no issues but clearly we're not done with this yet...
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
I checked one built in Oct of 19 and it has an update available for the instrument cluster. I would ask your dealer if they did a software update to it or you can PM the VIN and I can check if its been done.
breddy
Orlando, FL
2020 Explorer ST
Thanks a ton. The dealer did discover that there was an update and they applied it. However the moment she pulled into the garage and put it in P, the effing thing went black again. She headed straight back and they are ordering a new cluster.
breddy
Orlando, FL
2020 Explorer ST
Well after 5 days in the shop and a replaced "gateway module", the ST was back home for about 36h and the screen went black again. Off to the dealer. I'm keeping records in case this turns into a lemon law situation.
peterk9
Staff member
Moderator
Callsign
VE3
Bad APIM?:dunno:
breddy
Orlando, FL
2020 Explorer ST
Bad APIM?:dunno:
Nobody really knows at this point and I'm pretty unfamiliar with all the bits that connect the higher tech parts of these vehicles. I've called Ford and they are initiating the buy-back process which will escalate to a regional rep since we're on try #4 to resolve this. I'm not bothered about whether they buy back or fix, just want our car home. We've had it home for about 5 of the 14 days we've owned it.
breddy
Orlando, FL
2020 Explorer ST
So I think we're in the clear. On visit #4 (and after initiating a lemon law claim with Ford), they replaced the whole cluster and and said they found some bad wiring. Some things are working now that hadn't been at all since the get-go, like some of the e-nanny features and whatnot. The car was so new and we only had it for a few days in total that we hadn't even gotten to the point where we noticed them missing.
Frustrating but as suspected, Ford made it right and we're enjoying the ST!!!
N 2020 Sync 3 / In Vehicle Technology 22
Similar threads
Sync 3 screen goes blank
