Talon1
- May 18, 2013
- Seabrook, tx
- 1996 explorer
I have seen a lot of references to go to the dealer to have your abs bled, solenoids purged/cycled or whatever. NOT NECESSARY! It's easy to do. Here is my story.
I have a 2001 Explorer Sport. #My teenage sons wore the front brake pads down to the metal. #Drivers side pad actually came off and the metal backing got bunched up between the shield and rotor. #Pretty cool stuff. #He called me and told me there was smoke coming from the drivers front wheel. #Awesome! The piston rubber bladder completely blew out and brake fluid was running out. I limped it home using the parking brake only. I ran a red light because I couldn't stop in time. It was fun. No one got hurt.
Anyway, pads weren't my problem. #I replaced, both sides, pads, rotors and calipers. #Hmm, looks like a race car under the wheel wells. #Put it all back together, bled all four wheels and pedal goes all the way to the floor and there is only very little braking at the end of the pedal. #Sounds like a master cylinder, right? #The bleeding was doing nothing, by the way, so I did it again.
Replaced master cylinder, bench bled (I did the best I could, but realized I would have to be extra good on the wheel bleeding after the leakage during installation). #Still no brake action. #Exactly the same thing, no braking until the end, towards the floor after bleeding all wheels twice, again.
Was I supposed to pre bleed the calipers, somehow? #I did bleed the master cylinder after installation, twice. #I was having some problems bleeding the fronts, as they didn't seem to be flowing as well as the back. #In fact the passenger side wasn't flowing at all.
You can bleed the abs without the expensesive solenoid cycling machine. #It's pretty easy. #Focus on the calipers. #Remove them from the rotors and pump your brakes until the pistons come out. #I put some spacers in the caliper to prevent the piston from coming completely out. #Then remove the bleeder valve and the brake line. #Don't drain the caliper. #I stuck cotton balls in the brake line to reduce drainage. #MAKE SURE YOUR RESEVOIR IS FULL BEFORE DOING THIS! #Hold the caliper flat, so no fluid spills and proceed to pour more fluid into either the brake line hole or the bleeder hole, all the way to the top. #Might want to shake it a little to be sure as much fluid gets in there as possible. #Then reinstall the line and valve and take a c clamp and press the pistons down all the way. #I did this three times each side and fixed air in the abs system. #It is basically a reverse bleeding method and works great. I am sure I am not the only person who has done this, but I couldn't find it anywhere. A family friend and mechanic for us for the past 25 years suggested it to me. Thanks Mike at the Z Center in Houston!
