David in NC
- May 7, 2005
- North Carolina
- '97 XLT
It seems that my son has the dreaded blend door failure on his '97 XLT. Luckily it failed in heat mode so I don't have to repair it immediately.
I bought a Dorman replacement door from Advance Auto Parts for $12. Is it a direct fit replacement or does it require modifications. I plan to gain access through the bottom of the plenum. Will the replacement door fit onto the actuator shaft without modification? I read most of the thread in the blend door sticky. Any other advice? Thanks in advance.
