Blower Control Issue
Joey Threesticks
Omaha
2007 Explorer Limited
Alright, this one has me stumped.
I've got a 2007 explorer limited with the dual automatic climate. Air works great, heat's even better. Only problem is the fan only works on high.
I've owned a couple of older cars and had to replace the resistor pack on those, I'm assuming this one uses something similar. However I'm not certain that is the issue. When I've got the climate control set to say, 75 degrees AC, and it reaches that temperature, the fan speed slows down to maintain. So the fan does change speed, but only in that circumstance.
Am I headed I'm the right direction with the resistor? They're about $90 as far as I've looked so I figured I'd ask.
D Hook
Omaha, NE
06 Explorer Limited V-8
When you use the thumb wheel on the left front of the hvac panel does the fan speed reduce? Manually controlling the speed may tell you if the resistors are working as they should. I have the same controls as yours and mine works the same way your's does. That is, as the interior temp reaches the setting, the fan speed reduces. If I want the fan speed to stay costant, I use the manual control..
Joey Threesticks
Omaha
Not quite. The thumb control works if I turn it all the way up (bypassing the resistive circuit I'm assuming) but will shut off if I adjust the fan speed down manually to any level other than maximum. However, when the automatic system reaches the temperature I've selected, the fan speed will reduce on its own.
D Hook
Omaha, NE
Got it. Sounds like you're on the right track with your diagnosis.
F Rear hvac control and blower fan location Stock 2006 -2010 Explorers 2
A Blower not blowing air Stock 2006 -2010 Explorers 1
E Weak Blower and Strange Smell From the Vents Stock 2006 -2010 Explorers 0
R 2006 Blower Motor Resistor Stock 2006 -2010 Explorers 5
Mitchs07explorer Does the gen 4 have a rear blower motor for the rear vents Stock 2006 -2010 Explorers 6
C 2010 Explorer XLT AC Blower speeds 1-3 not working high works Stock 2006 -2010 Explorers 2
D 2006 Explorer heater blower assembly Stock 2006 -2010 Explorers 0
M Rear climate blower won't... blow Stock 2006 -2010 Explorers 1
T HVAC blower buzzing Stock 2006 -2010 Explorers 1
0 07 Explorer blower motor resistor? Stock 2006 -2010 Explorers 16
N Loss of Blower Speed Settings Stock 2006 -2010 Explorers 5
R Solved My blower motor doesn't work. Stock 2006 -2010 Explorers 5
M Blower Fan only blow on 4 Stock 2006 -2010 Explorers 4
W 2007 Explorer Eddie Bauer - Blower Works Intermittently Stock 2006 -2010 Explorers 7
B Blower motor on high, low air flow from vents Stock 2006 -2010 Explorers 3
2 Blower Motor Resistor Stock 2006 -2010 Explorers 2
G Fan Blower Motor/ Help Please Stock 2006 -2010 Explorers 1
S 2006 Blower Motor Issue Stock 2006 -2010 Explorers 7
5 Blower Motor Fan Stuck on HIGH Stock 2006 -2010 Explorers 4
B 2008 Explorer XLT blower motor resistor procedure Stock 2006 -2010 Explorers 26
P HVAC blower stuck on HIGH Stock 2006 -2010 Explorers 2
F 2008 Blower Motor Lost 1 & 2 Stock 2006 -2010 Explorers 1
W How Do You Remove the Glovebox/Access the A/C Blower? Stock 2006 -2010 Explorers 4
B Blower motor issues Stock 2006 -2010 Explorers 3
P 08 Explorer dual heat blower noise (Mr Mousie's wild ride) Stock 2006 -2010 Explorers 4
R Does anyone know where rear a/c blower is located Stock 2006 -2010 Explorers 10
B blower motor switch Stock 2006 -2010 Explorers 0
S Blower Motor Help Stock 2006 -2010 Explorers 1
G Blower Resistor Location ('06-'10) Stock 2006 -2010 Explorers 0
P Defrost Blower Won't Shut Off Stock 2006 -2010 Explorers 4
S Blower Motor Stock 2006 -2010 Explorers 6
S Blower Motor Stock 2006 -2010 Explorers 0
H '06 Mountaineer fan/blower/AC issues Stock 2006 -2010 Explorers 4
M Floor blower outlet problem! Stock 2006 -2010 Explorers 2
P 2006 ford explorer blower fan runs high only Stock 2006 -2010 Explorers 6
T blower only runs on high Stock 2006 -2010 Explorers 1
S 06 Explorer XLS 2wd Code 2104, Wrench, Traction Control Lights Stock 2006 -2010 Explorers 0
H Replace just lower ball joint or whole lower control arm? Stock 2006 -2010 Explorers 7
H 2008 Ford Explorer Check RSC now ABs Traction control and wrench on Stock 2006 -2010 Explorers 4
T Front hubs and ABS, wrench, and traction control lights Stock 2006 -2010 Explorers 8
M Bulbs for Climate Control Backlight - 06 Explorer XLT Stock 2006 -2010 Explorers 3
W Plug and play upper control arm for 3" strut spacer Stock 2006 -2010 Explorers 1
D Cruise control light not working Stock 2006 -2010 Explorers 2
K Locked up - ABS light, parking brake light, air bag light, traction control light on. Stock 2006 -2010 Explorers 3
T Traction control light 06 Mountaineer Stock 2006 -2010 Explorers 0
M Climate control codes Stock 2006 -2010 Explorers 0
N Abs/traction control on, already replaced rear speed sensor Stock 2006 -2010 Explorers 3
D Driving down the road, lost power and Traction control light flashes. Stock 2006 -2010 Explorers 1
E How does the heater control valve work? Stock 2006 -2010 Explorers 4
C Add adaptive cruise control? Stock 2006 -2010 Explorers 6
Similar threads
