Blower motor resistor universal?
themartymac
Victoria
2008 XLT
Hey all, Is the blower motor resistor (non-auto-temp) generic across the various Ford models for a given year? I have a 4th gen explorer, and see lots of links for f150 and escape BMresistors, but they don't specifically say explorer. Looks identical in the pics though?
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
M Heater blower motor switch resistor A/C & Heater systems - HVAC 0
R changed resistor and blower motor but still only works on high A/C & Heater systems - HVAC 0
T Blower motor variable resistor on its way out. A/C & Heater systems - HVAC 8
S blower motor resistor location -2000 Explorer XLS A/C & Heater systems - HVAC 0
I Almost had a blower motor resistor fire A/C & Heater systems - HVAC 2
0 01 explorer blower motor won't turn off?????? A/C & Heater systems - HVAC 0
M Caution on installing replacement blower motor A/C & Heater systems - HVAC 0
Z Blower motor control module replacement part A/C & Heater systems - HVAC 0
E Blower Motor problem? A/C & Heater systems - HVAC 0
J 05 explorer blower motor stumped A/C & Heater systems - HVAC 1
K No middle blower motor speeds. A/C & Heater systems - HVAC 4
J A/C blower motor switch. A/C & Heater systems - HVAC 2
R 2002 Explorer. Blower motor. A/C & Heater systems - HVAC 1
P Blower motor lost bottom two speeds A/C & Heater systems - HVAC 2
I Blower motor speed control problem. A/C & Heater systems - HVAC 2
O How To: Troubleshoot 1997 V8 Blower motor A/C & Heater systems - HVAC 8
K Blower motor is making noise. A/C & Heater systems - HVAC 1
L EATC Eddie Bauer blower motor. A/C & Heater systems - HVAC 4
C Blower Motor 98 Explorer A/C & Heater systems - HVAC 2
C Intermittant Blower Motor on 98 Explorer XLT A/C & Heater systems - HVAC 0
D Heater Blower Motor Vibrates A/C & Heater systems - HVAC 7
K Is your blower motor going bad, and how to replace A/C & Heater systems - HVAC 4
S New Member, Blower Motor Relay or switch problem A/C & Heater systems - HVAC 1
P AC Blower Motor Replacement A/C & Heater systems - HVAC 4
L Blower motor A/C & Heater systems - HVAC 1
SuRrEaLNJ Loose terminals on blower motor? A/C & Heater systems - HVAC 5
D Motor blower new, but next to no air flow? A/C & Heater systems - HVAC 3
J Blower motor A/C & Heater systems - HVAC 11
S No A/C, Blower - 2002 Ranger A/C & Heater systems - HVAC 0
F 2013 Ford Explore Cooling and Blower issue - HELP A/C & Heater systems - HVAC 1
D Quick blower question A/C & Heater systems - HVAC 1
Y Blower not working front and back A/C & Heater systems - HVAC 1
H 2002 Edie Bauer Explore blower is posessed!! A/C & Heater systems - HVAC 0
D 98 explorer blower stuck on high A/C & Heater systems - HVAC 3
N 02 blower and evap core removal help A/C & Heater systems - HVAC 0
B blower resister help?? plug connection A/C & Heater systems - HVAC 3
B 97 explorer blower resistor location A/C & Heater systems - HVAC 2
G help, blower only works on high. A/C & Heater systems - HVAC 4
D Blower/Heater Vacuum Control Switch Questions A/C & Heater systems - HVAC 1
C 1999 Heater & A/C Blower A/C & Heater systems - HVAC 2
I Need help for Winter. (Blower) A/C & Heater systems - HVAC 7
B A/C blower problems. A/C & Heater systems - HVAC 1
B NO blower fan, A/C or anything. A/C & Heater systems - HVAC 1
V Fan/blower/ac working only intermittently 1994 xlt A/C & Heater systems - HVAC 5
D A/C blower issue A/C & Heater systems - HVAC 0
R Intermittent heater blower problem. A/C & Heater systems - HVAC 2
M Heater & A/C blower control are not working. A/C & Heater systems - HVAC 4
J The blower fan works intermittently. A/C & Heater systems - HVAC 2
E Can't get the highest blower setting.... A/C & Heater systems - HVAC 3
B Blower resistor switch. A/C & Heater systems - HVAC 3
Similar threads
