Blower Motor stops w/ braking, blows w/ accelerating? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
91explorer1009
NJ
91 sport
Weird problem, maybe someone has had this before? When I brake and come to a stop the blower motor stops working...as soon as I begin to accelerate it blows hard again. Its pretty much ok and blowing while at driving speeds.
I have replaced all three relays under the main big fuse panel, I have replaced the blower motor resistor and cleaned out the leaves. I have even cleaned the contacts for the blower motor and bent them in a bit to grab the connector. I took it out and it spins freely and sounds ok.
Before I replace the whole motor, is there anything else this could be. I hate throwing money at parts like this? Maybe someone has had a similar problem and knows something I dont. Thanks guys.
arco777
1994 Explorer 2dr 4x4
Try removing the blower motor, hold it up and check for play in the motor's shaft. If it's sliding back and forth due to worn out bearings, the brushes could be coming out of contact with the commutator.
91explorer1009
NJ
91 sport
No one else has ever experienced this??
