- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
is the vacuum line completely hooked up to the booster no leaks?Is there a reason why my break pedal feels the same as when the truck is off when it’s running is there something I need to swap over from the v8 truck for my brake system to work properly? And does anyone have a starter wire diagram because my starter is not working with the ignition only if I jumó it’s off but it’s connected with factory wiring diagram any advice helps thanks.
at least my sohc, the booster is the same out of a v8 as well. PNs are the same.My vacuum booster has a tag reading 5.0 liter.
You may need vacuum booster from donor
