3/8” to passenger side at the trans mount, 1” waaay too much
Heated
Exhaust
Gas
Oxygen
Sensor, sorry I’m old school
Lean codes are
Likely from running lean it means the mainstream 02 sensors are detecting too much air not enough fuel, the computer has dumped more fuel in an effort to compensate and was not able thus you get a code. Fox upstream sensors first, now that cam sensor code is gone, test fuel pressure the. Go drive it some more see if lean codes return
Lean is usually air leaks, un metered air, or low fuel pressure
