Body lift question? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Body lift question?
4LCKDSPORTRAC
I don't own a sport trac yet. However I am interested in getting a sport trac. I would like to fit 285/75R16 tires. Would the body lift be sufficent? How easy is it to install a body lift on this vehicle? Would I need to change shocks if I do a body lift? Is there anything else I might need or need to know doing a body lift? Thank you all in advance.
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
JohnnyO
Moderator Emeritus
Pittsburgh, PA
2020 Ranger
A body lift would be enough, although people have fit that size tire by just turning up the torsion bars and using wheel spacers. Bodylift does not change the shocks, it only lifts the body from the frame. If you do not have at least above average mechanical skills and access to a torch if you live in the rust belt, then I'd advise having a body shop do it.
If the Trac you buy has tow hooks on the front, they will have to go if you put on a body lift.
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
that is right, no welding,all bolt on , ,
just the bolts may be rusty and heat is usually needed to get them apart, only reason for a torch,
plance1
cincy ohio
2002 sport trac
cant you reweld the brackets on?
