jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
i just put on a 3" body lift and i did put the extension on it but its binding when i turn left and right.should i take the extension off and try it?does anyone make an aftermarket shaft that isnt super pricey?the rubber bushing has a crack in it so i need to replace that if i dont get an aftermarket shaft,anyone know where to get that at?also it looks like the seal in the gear box is leaking now because of the extreme angle,is there a way to tilt the gear box,or can i notch out the bolts holes in the frame?is there a thread on how to replace the seals in a gear box?
