Todd82TA
- June 21, 2009
- South Florida
- 2002 Explorer Sport 4x2
Hey guys! My car has a clunk and a grinding sound (like threads rubbing against metal) and I've determined that my body mount bushings are basically shot. I went under the car and discovered that the rubber bushings are coming apart in chunks.
The car is 100% rust free, not even surface rust, and I can still see all the original factory chalk markings... there isn't even grease under the car. So replacing the bushings shouldn't be too bad.
I figured the process would be pretty straight-forward once I got into it, and that I should clearly be able to see what needs to be changed. I've only bought 4 bushings at this point and I plan to replace the ones in the front (and eventually do them all as I get around to it). I bought two of each part number. How can I tell which ones go where? There is one part number which makes up the majority of all the body-mounts, and then there's one specific part number which is used for only two mounts. Which mounts on the vehicle are unique compared to the rest of them?
Anything I should know getting into this?
Thanks!!!
Thanks!!!
