Blown
- December 6, 2007
- 2000 X-Edge
I think it is a good idea. It should reduce emission of burnt oil and keep away the possibility of fouling plugs. What do you all think for boosted applications and/or do you run one?
I have been running my Kenne Bell boosted rig without the PVC valve, just a hose from crankcase to vacuum, as too much pressure was building in the crankcase. It would push-up the oil dip stick and actually pushed some oil up when at 9+lbs of boost. It is getting some oil in the intake pipe at the PVC hose. I ordered a Moroso oil/air separator from Summit Racing to install and capture that oil. It was a little spendy unit but came with everything, hose, mount, hardware, fittings, including a tap at the bottom with valve to drain the oil. I will post-up some pictures later when I install it.
