Boot or not to boot? That is the question!
Positive Vibes
Santa Cruz, Ca
'94 XLT
Ok, I toasted another passenger stub shaft. Figured I'd replace all the front passenger side axles, bearing etc. I couldn't get the yoke axles to seperate. After pounding them apart I came to the conclusion that the boot that covers the slip yoke is actually holding water and mud instead of shielding it.
So on the front axle slip yoke, Boot or no boot?
4x4junkie
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
Without a boot, you'll just have dirt & rust seize up the splines.
If it was holding water, it obviously was not sealed well (or had a tear in it). Try using hose clamps on it, and make sure the dust cap in the end of the yoke isn't damaged or missing.
Positive Vibes
Santa Cruz, Ca
'94 XLT
Thanks but I choose to not to install it. I will see how it works out.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
I ran without a boot, not good
Run the boot and make sure the seal on the female side of the slip yoke is in good shape too. The boot needs to be secured TIGHT on both sides, I use some silicoln on there and I now use METAL zip ties to hold it in place
Positive Vibes
Santa Cruz, Ca
'94 XLT
Well now you chime in after I installed the axles and spindle. :p: I guess I can just pull the spindle and install the boot.
What was "not good" about not running the boot?
Oh and any info on the Metal zip ties?
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Metal zip ties harbor freight. Pull those suckers TIGHT
I wrap the end around my needlenose, pull very tight, then bend the clamp into place to hold it tight and fold it back over itself
Without the boot the grease comes out, likely because it gets washed out with sand and water
seth247
Tulsa, Oklahoma
'92 XLT 4X4
si señor. No boot = muchos problemos!
Also I'd use metal hose screw clamps, the kind with the notches all the way along it.
Might be easier than the zip ties. IDK
Positive Vibes
Santa Cruz, Ca
'94 XLT
Thanks guys. I pulled the spindle and axles and installed the boot. She back up and on the road now.
I was also thinking about using hose clamps. Thanks for the info!!!!
C shifter boot Modified 1991-1994 Explorers 2
4 removing shifter boot??? Modified 1991-1994 Explorers 5
C Steering mod question Modified 1991-1994 Explorers 5
Y F150 coil seats question?? With stabilizer bar on my 92 explorer 2wd Modified 1991-1994 Explorers 23
V Strongbox Shorty install question Modified 1991-1994 Explorers 3
W Big 3 upgrade question Modified 1991-1994 Explorers 4
HSlough Part number question Modified 1991-1994 Explorers 9
HSlough rocker assembly question Modified 1991-1994 Explorers 2
D Manual transfer case question Modified 1991-1994 Explorers 7
P f-150/Bronco spring question Modified 1991-1994 Explorers 2
V James duff 5.5 lift question/problem Modified 1991-1994 Explorers 1
T Question about particular setup Modified 1991-1994 Explorers 3
B shock question Modified 1991-1994 Explorers 3
W Manual locking hub question Modified 1991-1994 Explorers 1
B Lift question Modified 1991-1994 Explorers 3
V Front Spindle swap Question? Modified 1991-1994 Explorers 4
Dumple auto to manual hub question Modified 1991-1994 Explorers 2
W F150 spring question Modified 1991-1994 Explorers 3
W Extended radius arm question Modified 1991-1994 Explorers 5
B 302 valve spring question Modified 1991-1994 Explorers 6
B Radius arm cross member question Modified 1991-1994 Explorers 2
B 302 question Modified 1991-1994 Explorers 4
W Wiring harness question Modified 1991-1994 Explorers 2
D Roof rack question Modified 1991-1994 Explorers 3
R seat swap question Modified 1991-1994 Explorers 5
H The question of the brake booster Modified 1991-1994 Explorers 4
S 5 speed question Modified 1991-1994 Explorers 3
timtimtimajim Non A/C conversion question Modified 1991-1994 Explorers 10
A New Member! Stock>Mod Max tire size Question Modified 1991-1994 Explorers 8
G quick engine swap question Modified 1991-1994 Explorers 3
J 5 speed question Modified 1991-1994 Explorers 8
WormsExplorer Question for the First Gen Peeps :-) Modified 1991-1994 Explorers 12
T Brake conversion question Modified 1991-1994 Explorers 1
D 94 explorer lift question Modified 1991-1994 Explorers 4
K Soa question???? Modified 1991-1994 Explorers 3
1 4" lift question! (not about tires sizes or anything clearance related I swear) Modified 1991-1994 Explorers 9
S Lift Question Modified 1991-1994 Explorers 6
M Question to those who have installed James Duff coil buckets Modified 1991-1994 Explorers 4
C 8.8 Junkyard LS Question Modified 1991-1994 Explorers 6
R 06-11 ranger mirror question Modified 1991-1994 Explorers 10
S transmission question Modified 1991-1994 Explorers 13
F Question about front end leveling Modified 1991-1994 Explorers 1
M Motor Swap Question Modified 1991-1994 Explorers 13
S Dumb question, spare tire and roof rack Modified 1991-1994 Explorers 15
5spdman fun little on-board air project/question Modified 1991-1994 Explorers 15
S Dead Horse question. Modified 1991-1994 Explorers 5
S 93 Explorer Air Intake Question Modified 1991-1994 Explorers 17
C IAC Valve question Modified 1991-1994 Explorers 2
S Quick question need quick answer please Modified 1991-1994 Explorers 19
R Swapping my 2wd 5 speed to 4wd question Modified 1991-1994 Explorers 4
Similar threads
