I was really bored today, so I sat down and created this- most of it while sitting on my living room floor watching The Transporter. I started with a 15 Million candle power "Cyclops" halogen flashlight. I liked the light output, but the battery wouldnt last long because of the 130 watt bulb. So I happened to have to replace a headlight assembly in the CTS-v, so I had this laying around. The whole project was finished before The Transporter was over
What I started with :
And the HID guts...
I cut a piece of Lexan to replace the original glass lens. This was so I could bolt the projector reflector in.....
Took projector apart to use the raw reflector...
drilled holes to mount the projecotor. I ended up spacing the housing away from the Lexan so it could vent after this picture was taken...
mounted ballast in the housing....
And everything assembled...
I am charging the battery at the moment, so I dont know yet how the beam pattern will be. I have the original large reflector that I may use if this one doesnt work. This is a pretty common light to retrofit with HID, but most use a universal kit with a small ballast where they can use the original reflector. But the Cadillac ballast was too large and has the igniter on the bulb base, so it wouldnt fit easily.
And the HID guts...
