Borla Cat-back install on my 2014 Explorer Sport | Ford Explorer Forums - Serious Explorations
fjc2
MI
2014 Explorer Sport
Due to other life issues, I never got around to modding my 2014 Explorer Sport the way I had originally planned. Time to change that! First project, a new exhaust system. After much research and a ton of video watching, I decided to go with the Borla. A good friend of mine swears by them.
The next debate was if I could do this install myself, or if I needed to pay someone. The Borla instructions looked simple enough, though their system does require that you cut two pipes on the existing system. However, this also means you don't have to deal with ANY rusted/frozen bolts. I'm not a mechanic. I'm not even an amateur one, really - I can change my oil, change cabin air filters, and if I stretch I can swap out spark plugs. Recently, however, I bought some nice 10" rise ramps which gave me a ton of clearance under the vehicle, so I decided to go for it. I figured worst case, I have to drive it with no exhaust to a muffler shop and pay them to install! So, I ordered the Borla for my 2014 Explorer Sport (their part number 140656).
The big box of noisy fun:
Opening the box, it was all packed nice and securely with a ton of expanding foam packing material.
Bonus! A hat!
My first step was to unpack it all, lay it out carefully on my garage floor, and verify that I had all the parts. I didn't want to pull the stock exhaust off then find I'm missing a clamp or pipe. Here it is, layed out on the floor.
It all goes on with hangers (more on that in a minute) and clamps. 7 clamps total.
Time to get the Explorer up on the ramps. These RaceRamps are expensive, but very nice. Nice shallow angle to drive up, I never feel like I have to give it so much gas that I'm going to overshoot.
I wanted a bit more room toward the front, where the pipes need to be cut, so I jacked up the front passenger side and put some 4x4's underneath. In this picture I've also moved the floor jack under the car, lightly supporting the stock exhaust so that it won't try to move downward and pinch the sawzall blade as I cut.
Under the Explorer there's a large muffler. You cut the two pipes right in front of that muffler, on the side toward the front of the car. The Borla instructions show it nicely. Make sure you have a good blade, and keep in mind that the two pipes are relatively close, so be careful that when you're cutting one pipe, you aren't just bashing the front of the sawzall blade into the side of the other pipe. There's plenty of room with no cables or hoses near here.
The cut pipes. Note that I have a jack stand supporting the forward portion that goes to a catalytic converter and the downpipes.
At this point, the only thing holding on the stock exhaust are exhaust hangers. No bolts, just hangers. If you aren't familiar with these (and I wasn't at all until I started researching 2-3 weeks ago), these are large rubber grommets that hang from hangers on the car. The exhaust has hangers welded onto it that go into the other end of the rubber hanger. Here's one from my car - you can see how the exhaust hanger has a ton of surface rust, while the hanger mounted to the car is corrosion-free.
Now the job was to get the exhaust hangers out of those rubber hanger pieces. They do NOT want to slide out of there- the rubber is pretty stuck to the exhaust hanger, and the rust certainly makes it hard to slide them off. The solution here is to spray some silicone spray on the hanger and rubber piece. Don't use oil, it will degrade the rubber over time. Also, there is a special tool just for getting these off, made by Lisle. It's $18 on Amazon and I don't recommend trying this without that tool!
Here you see that same rubber hanger after I sprayed some silicone spray on it, and I have the Lisle tool in place. The red arrows point to the two sides of the tool - it's basically a specialized set of pliers to push the end through the rubber hanger.
And here it is after the exhaust hanger is out. The large rubber hanger should stay on the car.
I worked my way back removing these hangers - there's 5 of them. The last two, directly above the exhaust tips were the hardest, as it was impossible to get the tool positioned. For those, I just sprayed silicon on the vehicle side of the hanger (non corroded upper hanger), and managed to slide the entire rubber piece off the car. At this point the stock exhaust can fall down so make sure you have it supported. Here it is, on the floor after I pulled it down off the jack stand. You can see the rubber hangers still connected to it, right above the tips.
Now it was easy to use the Lisle tool to remove those, and then I just slid them back onto the hangers on the Explorer.
OK! Now the stock exhaust was off. The hardest part is done! I think I had that done in about an hour. Putting the Borla system on is a piece of cake, since it's all in sections. Borla tells you to start from the front where you cut the pipes, and install piece by piece. Make sure you slide clamps over the connections before you slide the pipes on, but do not tighten them at all yet. Pro tip I learned the hard way - think about the orientation of the nuts, I didn't and that caused me to have a few clamps a bit harder to position. As you go along, you'll be sliding sections on and hanging them on the hangers - they'll go into the rubber hangers easily as it's nice clean stainless steel. A squirt of silicone spray helps as well. No tool needed, I could slide them on by hand. Unfortunately I didn't take any pictures along the way here, but it's very easy and the Borla instructions were fine.
Once it's all on, it's time to play with the exhaust tips. Get them set where you want them, centered and so that both are sticking out the same distance. Then, working from the back to the front, tighten the clamps. I only lightly tightened them at first - tight enough so that the pipes couldn't slide, but not torqued down yet. Keep checking to make sure the exhaust tips are still positioned correctly. I used a cordless impact wrench to lightly do this. Here's the exhaust on my car, some of these may be before I tightened the clamps. When I tightened them, I tried to position the bolts as much to the side as possible. In some areas that wasn't possible, or I was concerned the clamp bolt would be too close to the underbody and might rub/rattle.
After that, I went back with a torque wrench and tightened them down to the Borla torque recommendation.
You're done! Borla recommends you fire it up and use soapy water with a spray bottle to check the connections for exhaust leaks - I didn't find any.
I took it out for a test run (in the rain, unfortunately) - it's just the sound I wanted. Deep, throaty growl when you start or any time you hit the gas. When just cruising, it sounds nearly identical to the stock exhaust. I can't wait to drive it some more today!
Yep, drove it in the rain and now the tips are no longer spotless.
Total time it took me - I started around 9am, and had it completely done at 12:45pm. And I took a break to eat a meal and have a cup of coffee after the stock exhaust was off. I figure it was about 3-3.5 hours of work, and that was taking my sweet time.
Great write up and pictures! Congrats on the DIY project-that feeling of "accomplishment" is a nice one.
Nice write up on the exhaust. I'm on the fence about doing this on mine since I still want to keep it a quiet ride. What are your thoughts on the setup? Any drone in the cabin? Can you post a audio clip of the final product?
Here is a clip I found using the Forum's handy 'Search' feature. Not sure if it is the same system. My Platinum Explorer
Yeah I've watched this, and still kind of on the fence. Hard to make a six cylinder sound "meaty", and not end up with the raspy tin can sound.
I don't have any audio clips as of yet, but it sounds to me just like the Borla video here. (Note - that video starts out showing the stock sound, keep watching to hear the change with the Borla setup).
I haven't noticed any drone at all. When holding speed, such as 45 down a road, it really doesn't sound much different than the stock exhaust. It comes alive any time you hit the gas. This morning I went through McD's drivethru, and rolled all the windows down while I was waiting in line with the building right next to me. You know how that always seems to amplify sounds from your vehicle? I thought mine sounded great. Not far off stock while idling there, but deeper.
I agree, it'll never sound like a Mustang GT V8 - but I'm ok with that; it's not what it is. But this is a much sportier sound, and it doesn't sound like every other Explorer out there.
The other video posted above (Jon Noriega's Explorer Platinum) - I *think* he also has different downpipes. I'm still running the stock downpipes.
Nice write up !!
Excellent write-up!
The Race Ramps are nice I have a set but not the type shown in the photo. The ones I had for my Taurus SHO were the shallow type. The ramps were only about 2-3 inches up. I primarily purchased them as more of a way to lift the front fascia a little higher so that I could get the regular jack installed to safely install Jack stands. I was mainly using them to lift for oil changes but the race ramps provided enough clearance to get in at the Filter and drain plug. Good write up and detailed photos.
These RaceRamps give a 10" lift, which is really nice. They are pricey, though! Maybe next spring I'll pop for a quickjack.
I have a axle jack from Harbor Freight that worked well. I also installed a cross bar adapter that centers on the Axle Jack but widens the jack area to allow lifting of entire front axle at once. (Brakes, struts, CV axles etc...) Lifting both at once you can install the jack stands at once and make sure the front suspension is level after lifting.
Bonus! A hat!
Been thinking about a custom exhaust for my 2013 Sport for some time. It seems that this system is the best alternative for that. MA has emissions standards and to my knowledge as long as I don't mess with anything from the cats forward (which have all the sensors) the engine computer should adjust to any change in velocity without causing any code problems (I hope). And, as such, I have contacted a couple of repair shops about doing the install as I don't have anyplace to do it except the driveway, plus, I don't have the extra tools required to do it. I am waiting for the shops' response as to the price for the system and price to install. If they want me to get the system and bring it to them--I can do that. Any suggestions from you readers would be appreciated. I'll let all of you know how this endeavor comes out. Thanks. Honky.
Had my shop (Ultimate Car Care in Ayer, MA) order and install the 140656 on my '13 Sport. Was $935 for the pipe plus $58.44 sales tax plus $180 for two hours labor for a total of $1,173.44. Forced Carlos to take $40 to bring the old pipe which came down in one piece to the house for me (he was going to do it for free). Sounds like all the videos on this and Borla's site depict.. I did notice that on the highway, it seemed to need even less throttle to maintain 65 mph than before. Seems to work well with all the forced air mods I've been doing. No drone at steady speeds. Growls when you juice it. Will run a combined mileage check in the next few weeks by driving it like most people would. I'll let you know what happens, then I'll go back to flooring it just for the fun of it. Later. Honky.
Checked the mileage twice. The first was about 45% city and 55% highway (62 mph in cruise control). Drove it rather gentle like with only a couple of on-ramp near floorboards. Came out to 17.993236 mpg. Then did another the way I like to drive it and this one was about 20% city and 80% highway which came out to 19.259843 mpg. All that highway running accounts for the added mpg. Will try to do one that is mostly or all city. I expect that one to drop to 16 mpg or so--we will see. Engine just feels stronger. See my comments on "air intake--from where?" where I did some mods to try and pressurize the intake to the air filter box. That, plus the Borla, seems to be about as much as I can do to it without putting a tuner into the system. I'm not so sure I want to do that as I have heard rumors that FORD can tell if you do a tune and remove it later so as to appear that nothing was ever put in to start with. Who knows if that is correct or not. Until next test. Honky.
Did another mileage check. Never went over 45 mph. Through a couple of towns with 50% of it at a steady 25, 30, 40, or 45 mph. Made the trip 6 or 7 times. Not much stop and start mileage. Engine was never working hard, just coasting along. The mileage came back at 19.997 mpg. 40 to 45 mph seems to be the sweet spot for mileage the way it's set up. Honky.
Hi all, I know this is a pretty old thread but… can anyone tell me if the borla exhaust tips can be removed? (Without cutting them off)
I’m ordering an exhaust system this week and my wife is dead set on black tips. I don’t want to pay the extra $550 for the livernois exhaust but I also don’t want to just paint the tips either, hoping maybe I can just buy some black chrome tips and swap them onto the borla system :).
Appreciate any replies!
What model number were/are these RaceRamps as I would like to get a set? Honky.
FYI, the member you quoted was last seen here on November 15, 2019.
