Originally posted by CQ7String
No offense to any MTX users, but one of the reasons that he's unhappy with the subs is that MTX is low-end gear.
Hmm.. MTX actually has some of the best 'market' amps you can buy. They send out good clean power, have low current draw, low heat output, and are underrated (Usually specs list at 12.7-12.9v.. Inside your car, they will be recieving 14.4v, so you do the math).
There's a lot more to a balanced sub setup than just dumping a cheap amp with a high wattage rating labeled on it (chances are it's actual RMS are lower than the 150 it lists), putting subs in a box and turning the gain up.
- CQ7
It's a 1500watt amp. That's RMS. If you buy it new from the company (MSRP ~$800), the birthsheet will probably tell you they tested at closer to 1700wrms.
I fail to see how this is budget equipment.
:edit:
To the original poster: Keep what you have now. Listen to it, enjoy it, tune it, etc. Your ears will tell you what you're missing (if anything). You can hear 100 different people tell you about 100 different speakers, but you're still where you're at.
Don't drop $1000 on new equipment if what you have might already satisfy you. If you find the Boston's lack in SQ, then do some research and see what other driver's are recommended for SQ. If you think you might want a little more push, start looking into drivers that offer a good mix of the two.
The fact is, most of these speakers are all about on the same level anyway. In order to compete (and make a living) you basically have to use the same format and formula that everyone else uses. They'll tweak a few things here and there, but it basically all comes down to product identity.
It's just like buying a new car (on a smaller scale of course). You like fords? You bought an explorer. Someone else might not like ford as much, so they bought a wrangler. Same concept, different application. That doesn't mean one is better than the other, it just means the consumers had different tastes in products.
I could go on and on, but I'll end it here.
Just use your own ears and your own judgement. That's really the only way you're going to know what needs to be changed or fixed.
