SilveradoCA
- July 19, 2015
- Alberta
- 2011 Explorer Ltd AWD
Hello,
I recently bought a 2011 Explorer Ltd AWD (w/tow package and MFT, w/o Navigation). It has ~150,000Km on the clock, and is generally in very good condition. The mechanic's inspection report was clean (save for needing new tires, which were mounted, balanced and an alignment done.)
It drives, handles and rides nice and smooth, quiet, and with ample power.
After 6 weeks of ownership, I'm pretty happy with it, but have a few concerns; some minor, and some less so.
1. Faint wobble on acceleration, up to ~20Km/h. I've read the long thread here about this issue, and if it doesn't indicate an imminent failure of some sort, it really doesn't bother me much. I can live with "characteristic of the vehicle" in this case.
2. Intermittent pulsing in brake pedal on braking. I intend to check the rotors with a dial indicator when I get a chance, as I suspect a warped rotor. It feels like the rear end - not really noticeable in the steering wheel. (I've read the threads on the sticky rear brakes, and will look at that issue also.) Anything else I should look at here?
3. AGGRESSIVE shaking in steering wheel under hard braking from highway speed - also intermittent. This one bothers me a little more, obviously. When braking hard from highway speeds (>110Km/h), I have occasionally experienced a hard shake in the steering wheel... but not every time. A bad rotor should exhibit this every time, right? What should I look at here, other than brakes? Is it possible this is somehow related to the traction/stability control system? It does not feel like simple ABS actuation, at all.
4. No matter what setting I select in the vehicle settings menus, I cannot get the coloured alignment grid to show up with the backup camera. I did perform a 'reset or reboot' of MFT from the menu. I grew very fond of this feature on my '12 SuperDuty. Is it possible for the camera to fail? (The picture from the backup camera is also much blurrier than that of my '12SD... and yes, the lens is clean.)
5. Every time I start the vehicle, MFT/Sync displays a message received from BlackBerry Assistant. If I read or listen to said message, it's telling me the date, time, weather, and what appointments I have in my calendar that day. Is there a way to turn this off? I can't find anything in my BB about this, so assume it's something on the Sync side? Of course, I can't find anything there either...
TIA for your help on these items. I'd be happy to give clarification if needed.
