Valleriani
- February 23, 2009
- Enkoping, Sweden
- '97 Explorer 4.0 SOHC V6
Hello there!
I just bought a nice explorer yesterday with the lady, we are pretty happy with the car.
For the most everything was rebuilt/fixed on the truck, only minor issues from what I can tell, but I'll need help figuring these out! I've checked a few links so far here but I'm pretty new to these forums so I'm a bit confused as well.
First issue: The instrument panel and the lights behind in the middle (where the radio is, behind there) are not working. The dome lights work, the dimmer switch does work (Can turn on the dome light this way, the windows going up and down do work as well for the most part. I've read about some minor issues with changing wires in the dimmer, but I don't really think that is the case (But I'll probably do it anyways in the end..) The lights such as 4x4 or battery light, etc, do work, just the night time instrument panel lights, like reading the speedometer is pretty impossible at night with no lights! Any suggestions? I did find a wiring diagram at http://www.scribd.com/doc/10112665/95-Explorer-Diagrams for a 95, but should be fine for my car, but I'm not a 'huge' techhy on what I should look at first. I also found a how-to on removing the dashboard panel which was helpful at http://www.explorerforum.com/forums//showthread.php?t=230211 ..
Second Issue: The front driver door doesn't open with the remote (stock remote), so I have to open the door with the key manually. I'm not sure what I should be searching exactly for this one. Basicly all the other doors are great, so I'm guessing it's something like a module? But I'm not sure what I should do here, I probably have to remove the whole door panel I think... Are there any diagrams for this and what I should 'replace?' I'm guessing some sort of module like I stated above, but I'm not sure of the part name, etc.
Third Issue: The battery light is on, and likes to stay on. The battery is brand new, and the alternator is charging, about 13.5V when running, so I believe it is charging just fine. Had it on a nice long drive and there were no issues really or 'battery loss' etc.
Overall I'm very happy with the truck, it rides very smooth, and having a 4x4 is great for parking here at the moment, (Goes over those snow hills nicely!)
