Alright so I went to pull a part today for the explorer.
Even though I scrubbed and cleaned the carpet, It just wasn't clean and still smelled.
Every time It rained and I got the floor wet it smelled like puke... :gross:
So, I went back to the explorer I got the clean leather seats from and got the carpet!
I also got the Fog Light trim, and a set of foglights so I could mess with them as a possible fog retrofit.
I got home and power washed the carpet I got from Pullapart. So Clean, no smell!
I also replaced the header panel since I picked one up last month from the junkyard.
Installed fog light trim, fog light, header panel and tightened it all down so now
the headlight doesn't shake/vibrate. It was killing me on my retro being bouncy. FIXED
So I'm going to let the carpet fully dry out in the garage for i don't know probably a week. Just want to make sure it's 100% dry on the underside before installing it.
The main issue I have is the noise it makes, but hell... 230k and $1,300 I think just waiting for the motor to crap is my best option. Then throw a low mile motor in....
The tires are great, everything else is great. Sure, it doesn't have a sunroof but
*** it... Not making a payment or out much on it anyway.
While I had the bumper off I noticed the support bar would be perfect for mounting
the 23" Cree led bar that I have laying around. Not sure I want to mess with it tho...
Father In law game me this really nice matco tool box as well
The carpet I got from the junkyard. The top is the cleaned side, bottom about to be.
The reason the headerpanel needed to be replaced. They hit something and broke it all to pieces.
I also replaced the rear diff fluid in hopes of the howl going away some.
No luck on the rear end howl (COMMON) but it needed to be replaced anyway.
Nasty nasty
Filled it with new Mobil1
I used 75w90 because the diff was stamped with it... Guy at the store said it called for 90w140 but I figured maybe the diff was
swapped out. Either way just wanted to play it safe. Heard though going to the 90w140 could help make some howl go away but oh well.
Also, I used Mobil1 LS (Limited Slip) even though I don't think I have it because there was absolutely no gear oil without the LS additive already in it...
