brake fluid change | Ford Explorer Forums - Serious Explorations
brake fluid change
William Schumacher
Yonkers,NY
'99 Sport 4X4
I started feeling what seems to be warped rotors on my '99 sport,
so I ordered a full set from A R T with the slide pin grease and pads,
and the brake fluid { 4 quarts }
however....I wanted to find out if there is a special tool /procedure needed to do the job of changing the fluid ....being an ABS system and all.
thanks,
It can be done without special tools, but it's a lot easier if you power bleed them. Easiest way is take it to Monroe and let them do it for about $20.00 (fluid included)
thanks Jeff :,since I have a quality fluid coming with the rotor kits,do you know if a place like that could load the machine with MY fluid ?
that would be the ultimate,
thanks, again
