kfdisme
- May 13, 2015
- Houston, TX
- 92 Explorer Sport 4WD
I've had a brake fluid leak for a while that was kinda mysterious, as I couldnt see where the fluid was exiting the system. I've since noticed that the brakes are verrry touchy, meaning a little pedal will cause the front brakes to lock up. This vintage exploder only has rear-wheel ABS. I've noticed that the bottom half of the brake booster appears kinda wet and am assuming the fluid is leaking into it. So my questions are:
1) What do I have to fix/replace to remedy this?
2) Can this be done under shadetree circumstances?
I do have a Hanes manual and they make it appear that this has to be done professionally...
