Hank
- October 19, 1999
- Cape Coral, FL
- '91 EB
When I push in my brake pedal I hear a whoosh noise and the pedal will go down easy about half way. During this time I have good/semi normal brake action. About halfway down the pedal gets real hard to push pretty much stops, brake action will increase slightly but you really have to stand on it.
Pumping the brakes makes no diff.
The brake pedal does not go to the floor. I can get it to the floor if I open up a bleeder so I don't think I am loosing pressure or fluid.
Front pads and rear shoes are new. The fluid is new. Rear cylls are new. Braking action is pretty good, as good as it gets with 33's and stock brakes. No fluid leaks, no pulling to one side, flex lines are new oem with no cracking or swelling.
Any ideas? Your Ex brakes do this?
UPDATE: Today the master cyll went out. Replaced it and hoped this would clear up but it did not. Same thing, open a bleeder and you can put the pedal to the floor. Close the bleeder and same situation as above.
Confirmed the pushrod from the booster to the master cyll is adjusted to spec .995 in.
I'd say braking is kind of weak, it is almost like I am running out of pedal travel and there should be more brake to go.
This is not a air/bleeding issue, I pumped a half gallon through the system again today with my power bleeder. And the feel is differant that if it was air in the line, remember I have brakes when you start to push the pedal.
Front pads are performance friction, rear shoes are Albany. Again, both new.
Only thing I noticed today was I can't get the RABS to trigger anymore. However not Antilock light on the dash. I pulled the fuse and it did light up.
Thought about a bad RABS valve but dont think that would explain the pedal stop. Thought about stuck calipers but no pulling and if they were stuck I would have serious rear lockup. I do have semi good front brakes.
Again, it is like I am running out of brake/pedal.
Bad vac booster?? How to test? It will hold vacuum for 4-5 pumps after stopping the motor.
Seriously baffled.....
