brake light | Ford Explorer - Ford Ranger Forums - Serious Explorations
brake light
monkeypothrower
Charleston SC
1993 Xlt
Alright, so my buddy told me i had a brake light out. So i go and buy the bulb. When i put the new bulb in, it still doesnt work. BUt when i turn the headlights on, it does. So i switched the bulbs from one to the other brake light and same thing. Only the right side one doesnt work. Could it be the brake light switch, if only one is out? Thanks -TJ
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
Check your fuses.
monkeypothrower
Charleston SC
1993 Xlt
its been checked. THis is strange, only one light now working. -TJ (also thanks for moving, sorry for the mistake.was just in a rush.)
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
Won't be a fuse or the switch.. I tuses the same fuse for both sides.. and the same for the switch..
Most likely you have a broken wire or dirty connection... Its time to start tracing the wire.. Follow the brake light wire (bad one) down to where you start to have power.. then fix the break (or dirty connector).
~Mark
monkeypothrower
Charleston SC
1993 Xlt
i fixed it. My next situation was finding the dirty connection. After about 5 minutes doodling around there was dirt in the connecters, not allowing one side of the connection to close all the way. Who knows how it got in there, but its done now, and thanks for you who tried to help. -TJ
