Brake lights on all the time and no turn signals... | Ford Explorer Forums
SplashMan
Cedar Rapids, IA
'93 Ranger
When the lights are on, the brake lights are all lit up and I have no turn signals or hazards. The brake lights will dim alittle when the brake is pressed and the turn signals with click once but not keep going. With the lights off every thing works normal?? I checked all the fuses and every thing is good. I did a search and came up with the multifunction switch as a possible fix. I could not find a writeup on replacing it though.
Anyone have any othe rideas what could be causing this?
yep... most likely cause is the mfs switch. There are a number of posts in and around this area as it is a common failure area. As for replacing, take the column shroud off and undo the two screws hold the MFS in place... unplug and replace.
