david4451
- February 9, 2015
- cotabato philippines
- 2001 ford sport trac
On the master cylinder, there is a "valve" that feeds The rear wheels and the brake line to the rear screws into it.
On this "valve" is a groove with an thin '0' ring on it, under the '0' ring is a pin hole and this pin hole is leaking brake fluid, only when the brake peddle is pressed.
Could someone please help me with why it is leaking like this, thanks in advance.
UPDATE: Pleased to say that I've fixed this leak, disassembled the "valve" and cleaned out deposits.
