VladoKE
- December 6, 2009
- Kosice, Slovakia
Hi All,
i had problem with brake noise at very low speed, pedal was with shaking resistance like braking during ABS actuation.
Noise was produces by ABS hydraulic unit.
First I changed Master brake cylinder, no improvement.
Then I changed ABS hydraulic unit,, no improvement.
Then I changed brake hydraulic lines, no improvement.
Then I changed ABS wheel sensors, no improvement.
Finally the reason was wheel hub assembly, where bearing was worrn, so I changed both wheel hub bearing assemblies and problem was gone
