hillre55
- November 28, 2017
- Medon, TN
- 2003 Ford Explorer
Good morning
I have a 2003 Ford Explorer, 4.0, 146,000 miles.
Issue: Brake Pedal Going To Floor After replacement of master cylinder after starting engine. Bench bled master cylinder and bled all four wheels. Before starting engine, I have no spongy brakes at all.
Have any of you experienced this issue after replacing your master cylinder? How did you fix it please?
I didn' even have this brake issue with the master cyliner that was replaced and it had bad seals (was leaking fluid
Could the brake booster be the problem although I didn' have the issue until after replacement of new master cylinder?
Could the new master cylinder be bad? I don' know if it's used or a brand new one?
Thanks
Hope to hear from ANYONE who has experienced this issue.
Have a good weekend
Thanks
Have a good weekend
