Brake pedal sticking | Ford Explorer Forums - Serious Explorations
MessiTom
central PA
99 Explorer 2dr 4ltr 5spd
Hello.
My dad gave me his 99 explorer sport. It sat for a few years and has a few very minor easy fixes.
I wanted to ask about one of these problems though. The brake pedal wont return back "up" after being pressed. The pedal isnt mushy or going to the floor. I havent had a chance to even give this vehicle a look over yet. I was just trying to gather some initial thoughts. In a spin around the block the drivers side front squeeks like crazy during braking.
Iam really hoping this isnt a booster or master cylinder problem.
Had the same problem in my F150, it was a bad booster...sorry.
Bill
probably the booster, but get the replacement booster with a new master cylinder just in case.
+1 don't replace the booster without the master cylinder as well...one may have contributed to the demise of the other. Also, be cognizant of the push rod free play adjustment-very important, don't just gloss over the instructions that come with the booster
Bill
Thank you for the replies. Ugh This truck looks like it sat in salt for 3 years. it looks to need rotors all around and maybe calipers. The brake fluid is nearly black.
I just remembered something. The pedal dosent stick if the vehicle isnt moving.
Does that make a difference?
I just remembered something. The pedal dosent stick of the vehicle isnt moving.
that says bad booster to me.
Darnit! lol ^
OK thanks again
It's always a good idea to flush out the brake fluid if a car has been sitting that long.
Flush and clean the calipers too.
Actually, it's a good idea to flush and replace the brake fluid periodically even if it's a daily driver.
I would have thought that the pedal sticking would mean the master cylinder needs cleaning out but as I've never experienced a bad booster I can't really say.
DOT3/4 brake fluid should be flushed every 2 years, but few people do this. I replace mine every time I do a brake job. While on the subject of doing brake jobs, you should open the bleeder valves before pushing the caliper pistons in. if you don't, you're just pushing a bunch of junk into your ABS module.
A Very good tip. Thank you. I do plan on replacing everything at the wheel ends first including the fluid
Did I mention rust? lol look at this rotor
Can anyone tell me what years I could get a booster/cylinder from that match my 99?
99-01 are the same. Reman booster can be had for $60+ core, new master cylinder is around 60, you're going to pay $100 for a junkyard takeoff of dubious background...
Bill
Thank you all for this info! This is greatly appreciated.
Hello.
I had that sticking problem , and the brakes would be smoking hot in minutes , it was the calipers stiking and I changed 2 front calipers and that fixed it
