Ramzi Nassar
- March 7, 2019
- Doral,FL
- 2012 Explorer Limited
Hi
I am getting the below error. Does anyone has any idea what the problem could be?
Code: C101A - Vacuum Pressure Sensor
Additional Fault Symptom:
- Circuit Voltage Out Of Range
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Antilock braking system
Freeze Frame :
-POWER_MODE: Crank - Power Mode Status
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Inactive - Hydraulic Pump State
-VPWR_ABS: 10.70 V - Module supply voltage
-VSS: 0.0 km/h - Vehicle Speed
Status:
- Test not complete
Freeze Frame :
