Brake problems | Ford Explorer Forums - Serious Explorations
Brake problems
Steve
Chandler , AZ
'94 XLT
Ok, After replacing all brake components ( pads, rotors, caliper's, and wheel bearings) I am having a heck of a time getting them right. When braking the trucks wants to pull really hard to the right. I have bled the brakes a number of times, double checked everything, even took one caliper back for a new one. I cant figure out why its pulling!!
Does anyone know if the HCU could cause that?
If anyone has a suggestion on something else to try let me know, Thanks in advance
possabilities
I would try a fluid flush first, then possibly a new master cylinder, did you have the rotors turned(resurfaced)???
Re: possabilities
[I put all new rotors. the master cyl. has two lines 1 front, 1 back, they both got to the HCU from there, it is 3 lines out that I can see, does anyone know if that is what controls that stuff?
