dieselhp07
- March 7, 2010
- Tecas
got a 2001 ford explorer. 2wd, xlt, v8. while back mt other half got a rock in behind the brake rotor and brake cover. in process of finding it i noticed the wheel bearings were out. so replaced them then my abs light come on. so i figured the collector ring got some grease on it or something. so disassembled again and clean and inspected. light went off. then now my brake pedal started pulsating. took it to a tech. with a scanner said my right front abs sensor is not reading correctly. changed sensor. nothing changed. never had the problem until that little pebble got in there. any help sure would be appreciated. thanks
