MnOldGuy
- December 1, 2020
- Hibbing,MN
- 2006, Explorer, XLT
I have a 2006 Explorer that is driving me crazy for over a year, and hope someone can tell me what is going on. This is a low mile (50K) that’s been in my family since new, and is used during the winter only so it sits for 6 months a year. The problem is a brake pedal that goes to the almost to the floor and won’t pump up. I’ve looked at every thread that I can find, and tried many things without success. I’ve worked on cars for over 50 years, so it’s not my first rodeo. Remedy attempts have included replacing the master cylinder, front calipers, front brake hoses, slide pins and trips to the local Ford dealer as well as a local independent shop (which now makes a total of less than ten times I have resorted to paying someone else to service my vehicles in those 50 years.
Here are the symptoms, and why only the front has been addressed. The pedal in the car has never been what I would call good and always seemed low and not really firm. It has gotten worse with time. It will stop the car, but no longer will engage the abs on dry pavement. I’ve run enough brake fluid thru it to fill a small pool. If I isolate the front calipers, the pedal is immediately rock hard and high. All the other part replacements have had no effect. When the car is off, the pedal is initially low, then as the vacuum reserve is bled off, the pedal gets higher (to about half), AND can be pumped up, but when the car is started, it immediately reverts to just off the floor, and it spongy enough to bottom out when pressed hard. I also can say that the pistons in the front calipers visibly retract after the pedal is released after being depressed. So each time the brakes are used, the first part of the travel is used to take up the slack in the calipers. I thought perhaps the rotors were flexing or the caliper was binding, so I took the calipers off the rotors and put a solid metal spacer in between the pads, and they continued to retract upon release. Finally, someone suggested installing a residual pressure valve for discs (2psi) in the line and I was convinced that this would solve the problem. So I now have one in the line between the MC and the ABS module (off the back chamber). No change! Needless to say, my frustration level is very high, but I hope the piston retraction issue will trigger an AHA moment for someone.
Thanks for listening.
