LG57
- November 29, 2018
- Katy Tx
- 1993 Explorer Sport
1993 Explorer Sport. I'm getting a brake warning light intermittently.(not to be confused with ABS Light) There are no leaks. The master cylinder is less than a year old. Occasionally, after backing out of the driveway, then moving forward, on first application the front brakes will grab, skidding the tires. At this time the warning light comes on and the ABS motor growls. I confirmed the growl is from the ABS motor by hitting it with 12 volts off the battery. It is noisy. Any ideas? Could the new master clyinder be leaking internally? How to test it?
