gearhead 007
- May 21, 2009
- CLT, NC
- 2006 EB 4WD
This is the list of parts, lessoned leaned and comments concerning the front brake job on my '92 EB Explorer 4 X 4, build date 05/92.
Parts List:
Bearings: Timekin LM603049
Race: Timekin LM603011
Wheel Seal: Timekin 4250
Rotor: EBC GD7035R and L
Brake Pad: EBC DP61272
Caliper Grease: Sta-Lube Part# SL3301 (MFG: CRC)
Bearing Grease: Valvoline Multipurpose Grease for Ford Lincoln Mercury Part# 632
Lessoned Learned:
- EBC Brakes are expensive.
- Small parts for the automatic hubs are not available from Ford. The hub is available from Ford for >$300.
- Use the bearing race that comes with the new bearing. The races removed from the EBC Rotor was chinese even though the rotor is manufactured in the UK.
Comments: In my opinion, the 2 most important safety components on a vehicle are brakes and tires. If either of these 2 components are deficient, the chance of an accident is high. This is the second set of EBC brakes I have used on my Explorer. I can say without a doubt, EBC Brakes are worth the money.
I use Yokohama Geolander Tires.
Automatic hub parts are expensive and I will go to a manual hub when the need arises.
The EBC and Yokohama combination works great for the driving conditions in piedmont NC. Most of my miles are on the highway and I regularly tow a 5X8 trailer with a 1/2 ton load. Make sure to choose components that suit your environment.
Parts List:
Lessoned Learned:
