RedDen
- March 14, 2012
- Calgary
- 2012 Explorer Limited
Hello guys,
Brought my Explorer recently for an oil hange.
While reading service report found this:
"rbrakes brakes require immediate attention disc less than 3mm, DRUM less than 1mm"
I searched Google all over and couldnt figure it out, what kind of DRUM it is?! All brakes are disc type brakes!
I am approaching 80k km and was suggested to do the following:
1. Brake fluid change - about $250
2. Cooling agent change - about $250
3. Transmission check and smth else - about $280 (with 20% off)
Moreover, all of the sudden got this:
"Recommend replacing both worn both rear upper arm rear bushings as they have excessive movement" (just re-typing from report, ) $971.51+GST"
What a rip off!!! Those bushings are about $50 each!
