Brakes too hard ??
X-North
Montreal
Hi
This summer I changed my rear drum pads in my 1992 explorer. A month ago I changed my front pads and made the discs resurfaced. Yesterday I had a leaking caliper so I changed it and bleeded only this caliper because there was still brake oil in the reservoir. But now its braking too muh i think... I roll at 20 kilometers per hour in my driveway and I press only a little on the brake pedal and I almost slam my head on the steering.... Any ideas???
glfredrick
Louisville, Kentucky
86-98 Ranger STX
I'd say that it is a sticky caliper and/or a bad residual valve.
I've never seen Explorer brakes that grabby...
Also, are the rears jacked up hard? If so, you might want to back them off a couple of turns. You have to use a brake spoon and a small screwdriver in through the rubber plug hole in the rear of the backing plate. Back off the adjusters a couple of clicks and see what happens.
Oh, and I typically replace calipers in pairs so they pull evenly. I'm not real big on one-side brake jobs of any sort.
X-North
Montreal
Driver side caliper was ok and braked ok so i did not changed it ...The brakes on this side was used correctly and the dust seal of the caliper was really ok so i tought the caliper was already changed because the truck is now 210000 km's and maybe more. I changed the passenger caliper because of the leak only. Can you post a picture or a link to show me what you mean by a Residual valve? The rear brakes are correctly adjusted. When i do that i start the truck and jack up the rear. I ask to someone to push on the brake pedal and i pry the wheel with a crow bar between the studs to turn it . I loose it until it can be turn with the bar and I finish relocking it a little just to be correctly applied.
glfredrick
86-98 Ranger STX
Here is a link to a good article that explains what is happening in the brake system that could cause it to drag.
Also, from what you say, I'd loosen up the rears a bit. You have them pretty tight considering that they are self-adjusting and will set up even more when you back up and hit the brake pedal.
http://www.thebrakeman.com/valvetechi
