break light problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
break light problem
cden
michigan city, indiana
2002 xls
i have a 2002 ford explorer xls. 4x4. the problem that i have is the brake lights stay on sometimes after i let my foot off the brake. i have to pump on the brake or pull on the brake pedal in order to get them to turn off. any ideas on what the problem is and how to fix it? thanks
cden
2002 xls
brake light problem
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
First thing I would check is the brake light actuator switch, which on most cars, and I presume the Explorer, is up under the dashboard and in contact with the brake pedal arm, just up from the pedal itself.
Usually a cheap part and not hard to replace.
cden
2002 xls
i know they are on because when i try to use my cruise control it dosent work. at night i can see the lights on when i get out. and during the day i usually catch it but sometimes they might stay on for hours until i catch it.
EasyRhino
Kailua, Hawai'i
That helps confirm it for me that it is the switch mentioned above.
