Mike_F
- November 29, 2007
- South Jersey
- 1998 Limited
1998 Limited - 220,000 mi. This happened to me three times, twice under identical circumstances. Cruising at 65 or so on turnpike for 200+ miles and gave it a little gas to pass. Not stomping on it, just accelerating. There was a very brief power loss followed by a loud bang, like slamming into gear or something. I thought for sure something had broken but the car ran fine for a few hundred miles and it happened again. Thinking it was the tranny, I took it to the local transmission guy. He didn't think it was the tranny after driving it and examining the fluid. He checked the tires and found the shortest tire was 1/4" shorter than the tallest and one tire had 15lbs less air than the others . (two different brands on front and back with 30,000 miles difference between the two, the small tire was one of the newer ones) He said this difference can cause problems in the transfer case due to the truck being automatic 4WD. Ford said the maximum allowable difference is 1/8" so I bought 4 new tires, made sure the pressure was correct and everything was fine for 500+ miles when it did it again. This time at slow speed trying to make a yellow light and the bang wasn't nearly as bad. I can't make it do it on-demand no matter what I do.
Any ideas? The truck hasn't had a tune -up in a looong time but otherwise runs fine. I did notice that I have to pump the gas a little when starting cold.
