Briggs and Stratton 20HP | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
96eb96
Albany, NY
96 EB V6 OHV 4WD
I guess it is a motor vehicle so it can go here. Anyway it is a circa 2000 20hp opposed "boxer" v-twin i/c.
Ran great, about 700 hours with some oil smoke at startup. Pretty well maintained, and I believe oil was at the lower end of the hashmarks, some leaked after this incident.
Starter had issues, and I tried starting it with an impact driver(prob a bad idea, I'm thinking that hurt the bearings).
After changing the starter gear to a genuine Briggs (I bought a new starter and the off brand gear, changed twice, lasted maybe 20 starts).
it ran for about 2 min, then I heard a terrible noise.
It smoked too.
There is some oil leaking too, but I don't see any cracks (some of the engine is concealed).
Now it can only make 1/2 turn by hand. I guess it threw a rod?
Worth to tear down? I don't think there are parts for this motor anymore.
I asked a local shop, he said if you got that much use out of a big box store engine maintaining it you should work here. He said you certainly got your moneys worth. He said to buy a new motor or a new tractor.
He also said it can't hurt to pull apart and see what is damaged, but it wouldn't be cost effective if a shop did it.
I fixed the hydro trans a few years ago, it had a loose bolt.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
donalds
Location
Stem
Nc
1999 ford explorer sohc
I fix and do full rebuilds on ALL small engines
Without dissembling you will never know
But sounds like a broken rod ..aluminum..
It happens
99% of small engine s have a standard bolt pattern
So just about any engine will fit
You will have to connect your wires
Kill
Start
Ground
+a.c. 12v for lights
+dc 12v for battery charging
Will take a few hours for the swap
Or obviously buy the same engine
Oh please don't use a impact that's what broke stuff in the engine
Use a drill instead
Parts are available on eBay for sure
Gary Crist
Location
TEXAS a whole different country $1K Green AWD
TEXAS
1997 AWD V8
Callsign
KI6FG
I don't know what the engine is used for but, here is a solution!
I do not know about fitment but, boy will it run fast! Can you find a used lawn tractor
cheap? How about Harbor Freight?
96eb96
Albany, NY
96 EB V6 OHV 4WD
HF has one vertical one that is 999. I've seen some briggs in the 5-600 range.
96eb96
Albany, NY
96 EB V6 OHV 4WD
It happens
Kill
Start
Ground
Use a drill instead
Yeah, I think now the impact did it in, although the small engine guy didn't think so. He said it was probably reaching end of life.
He also said if two starters got chewed up fast, that is another smoking gun.
Not an ordinary impact either, the HF battery earthquake :lol:.
So what if you use an impact to take off a stubborn crank bolt on a car? Not a good idea I guess
The shaft lengths for the PTO seem different though. probably will pull it just to see the carnage.
