major
Elite Explorer<br><img src="/forums/images/star2.g
- March 5, 2000
- Florence, South Carolina
- '98 V8 2WD XLT
Has anyone found a brighter map light bulb that will not melt the housing. I tried the 906 and it melted the reflector the holder and the black plastic deal to hold the bulb centered. Now i have had to buy a new lighting assembly to fix my screw up so i can have map lights. Just for future reference dont use the larger 900 series bulbs. For christmas i bought myself one of those lights you put on your head made by petzl. It uses three leds and puts out alot of light. almost as much as my mini maglight but with a slight blue tint and alot whiter. I was thinking since it only uses three leds and no real reflector maybe i could make a bulb based on it. So far the petzl paople have not written me back on if i can get some "replacement parts" or even a manufacturer of the leds. All it should be a matter of is getting a small piece of plastic and drilling three or four holes in it and adding a resistors to knock down the voltage to where it needs to be. If i get some info ill post it and get to work. Major
