Brightest 9007 bulb?? New Member Intro and HELP!
Tandra Eiland
Duck Hill, MS
2002 Ford Ranger Edge
Hello World! I am a New Member and I have a 2002 Ford Ranger Edge.
I CANT SEE AT NIGHT! I need the BEST HI/LO BEAM HEADLIGHT BULBS that are 9007 compatible. Please Help! But I don't won't to go Broke doing this.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
FlyingV3152
TN
1996 Explorer XLT 5.0
Your Sylvia Silver Star bulbs are really good, in my honest opinion, if you want to go with a halogen. You can go LED (I am biased towards LED btw) or HID but they are a little more expensive. Now if you get a good LED bulb they will more than likely out last your truck. Only problem with that is if you aren't using a projection headlight then they can blind on coming traffic and could end up getting you a ticket (depending on the state). What condition are your headlight assemblies in? If they are oxidized then that could cause reduced brightness. Also, are your headlights aimed properly (not aimed at the trees or at the ground)?
Tandra Eiland
Duck Hill, MS
Tandra Eiland
Duck Hill, MS
Well, Thank You so much! I think I need to get New Headlight Assembly AND the Sylvia Silver Star Bulbs! Thank You sooo much.
FlyingV3152
TN
You're very welcome! On a side note I'd look at Amazon for those lights. I believe they are about $20 cheaper there than Autozone or Walmart but don't quote me on that. Just make sure you buy from a reputable seller as well.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
toypaseo
Flunked daycare
outside shovelling snow
................ 96 XLT ™
I have Philips Xtreme Power bulbs in my Explorer and my Paseo. Great bulbs. The Philips Xtreme Vision bulbs are their replacement, so they might be even better.
fshskjp
2015, 2012 F-150
Purchased a set of F2 led headlights for my Explorer, the light is good. Much better than the halogen bulbs. The previous LED bulbs I had in the driving lights had cooling fans that proved to be annoying and failed to prevent one of the two bulbs from burning out. I cannot comment on lifespan since I've just installed them but I'm hoping that we'll get more than just a couple of years out of this set.
K Brightest NON HID Fog lights Performance Lighting 28
N Wanted brightest lights Performance Lighting 28
B Brightest Bulb Performance Lighting 9
S brightest 3157 bulb/led? Performance Lighting 3
K brightest offroad driving lights??? Performance Lighting 16
Z brightest replacement headlight bulbs? Performance Lighting 2
E Brightest PIAA's Performance Lighting 29
G 9004 and 9007 Headlight Bulbs - 40% Brighter DOT / SAE Compliant Performance Lighting 0
D hid 9007 high/ low beam kit Performance Lighting 13
I I bought a 9007 Bi-Xenon kit... Performance Lighting 16
SB98UKexplorer uk wiring spec needs adjusting to 9007 spec Performance Lighting 3
P Is the 9007 bulb in 2003 explorer Positive or Ground switched? Performance Lighting 3
R 9007-4 hid kits Performance Lighting 5
S HID or regular 9007 bulbs Performance Lighting 6
U 9007 into fog lamps (01 sport) Performance Lighting 0
hunterdan Philips Extreme Power 9007 bulbs Performance Lighting 2
aldive 9007 headlight conversion to HID Performance Lighting 41
hunterdan 9007 HID Hi/low Install Performance Lighting 42
K 9007 HID high and low beam Performance Lighting 13
carlover 9007 hid kits Performance Lighting 1
Afboy143 Differences in 9007 bulb watts? Performance Lighting 3
L Just installed 9007 harness from SUVlights.com Performance Lighting 20
9 Gauging interest on a PIAA 9007 bulb Performance Lighting 0
A PIAA 9007 Xtreme White Performance Lighting 4
M Anyone using the Catz 9007 HID kit? Performance Lighting 1
G Can I replace 9004 with 9007? Performance Lighting 9
T PIAA 9007 toasted Performance Lighting 10
S 9007 hid kit on ebay Performance Lighting 10
H 9007 Plug question Performance Lighting 5
aldive PIAA vs Silverstar 9007 Performance Lighting 15
mattadams PIAA xtreme white vs. superwhite (9007) Performance Lighting 5
S PIAA 9007 died Performance Lighting 8
yob_yeknom my opinion of PIAA 9007 headlight bulbs Performance Lighting 3
R PIAA 9007 Super White Headlight Bulbs Performance Lighting 0
N I'm changing my 9007 headlight bulb.......... Performance Lighting 13
Flounder PIAA 9007 Remarks Performance Lighting 18
J New 9007's worth the money? Performance Lighting 9
mattadams FREE SET OF PIAA 9007'S!!!! And the winner is... Performance Lighting 118
F 9004 Vs. 9007 Performance Lighting 15
A 2016 Explorer Sport Fog light bulb replacement help!!!! Performance Lighting 0
T 880 bulb connections Performance Lighting 0
S replaced headlight bulb... won't stay in now Performance Lighting 4
Paraphoe Interior lights bulb sizes Performance Lighting 6
blueka 99 Foglight Bulb fitment Performance Lighting 6
Tbars4 Field Testing - What's the latest Bulb's for First Gens? Performance Lighting 21
A Led Cargo light bulb replacement Questions Performance Lighting 19
0 HID fog light bulb 03 explorer? Performance Lighting 1
D Headlight Bulb Accessibility - 2012 Explorer Performance Lighting 0
F Led Converstion (Need bulb numbers) Performance Lighting 5
K DDM LED Bulb Warning Performance Lighting 2
Similar threads
