dlphelan
- August 26, 2014
- Vancouver, Washington
- 2001 Mountaineer 5.0 AWD
2001 Mercury Mountaineer 5.0L AWD
Water pump seized and had to be replaced. When taking it out, one bolt was pretty well stuck but I was able to ease it out after hitting it with PB Blaster and letting it soak.
Changed out the pump and put everything back together. I put anti-seize on all the bolts, to make sure it wouldn't get stuck coming out the next time. The same bolt that gave me problems earlier started to turn a little tougher on the way back in.
This is the bolt that, if facing the water pump, is on the far right. It goes through the water pump/timing chain cover and into the block.
I pushed a little too hard thinking I just had to get past a little bit of resistance and the bolt snapped off mid-shaft.
It broke just below where the threads start and there is nothing protruding that I can get a grip on.
In a fit of panic/idiocy I just put everything back together absent that one bolt.
Ran it for an hour and no leaking, but the whole thing is making me nervous. It's my wife's car and I can't have the nasty cloud of a possible catastrophic failure/leak hanging over her when she drives it around.
Any thoughts or advice?
BAH, I'm bad at the internet... Same issue, same bolt, already addressed in another thread. For posterity's sake: http://www.explorerforum.com/forums/showthread.php?t=209508
