Broken Motor Mount Bolts | Ford Explorer Forums - Serious Explorations
mlochala
Amory, MS
1998 Mountaineer AWD
Yesterday, I attempted to replace a motor mount bolt that thought had simply come loose and fallen out. Unfortunately, what I discovered was that BOTH motor mount bolts on the passenger side were actually broken off flush in the engine block.
I've never had very much experience or even good luck removing or drilling out bolts like this, much less in such a tight space as this. :scratch:
Have any of you had to do this before on your Mountaineer or Explorer?
If so, how did you do it and what advice can you give me?
Thanks,
Mark
If you don't the skills/tools to do this properly, then take it to a shop. You DO NOT want to dork up the holes.
Thanks,
Mark
I honestly do not know how you can do this without pulling the engine, there just isn't enough room to work, unless you use a Dremel tool to drill the old bolt out of the block. You can do an old drag racing trick to hold the engine down. A small length of chain from the block to the frame with a turnbuckle will do the tridk. Lets see how many comments we get about this.
LOL! Been a long time since I've seen that, but you're right...it'll get the job done as long as the other side is OK.
Bump
Looking for any info on the mount motor to block bolt size and length for a 2000 5L explorer
7/16 - 14 is coming up often but also trying to find the length
